Active Building Option Dialog
Column sorting is retained from session to session.
Annotated Elevations
Custom Building Option Visibilities added to embedded Annotated views on Plan Set pages.
Assign Building Options
Building Options that are currently enabled for a project display as bold in the Assign Building Options dialog.
Invisible Building Options
Lock Invisible Building Options option added to System and Project Options.
Locked Building Option
Items on a Locked Building Option can no longer be modified via Repeat Edit.
Plan Sets
Right Click
All Building Options that an item is assigned to list on the right click of the item.
Slab Footing
Footings will form correctly when two structural slabs on separate Building Options overlap and one of the Building Options containing one of the slabs is turned off.
