Where can I download the latest SoftPlan updates and installs?
What are SoftPlan’s computer hardware requirements?
Processor (CPU):
SoftPlan can be run on any PC which has a 64-bit (x64) processor from Intel® or AMD®. SoftPlan is not compatible with any device which uses an ARM® processor, regardless of operating system or emulator used. A multiple (4+) core processor is required. Multiple cores are more important than raw processor speed.
Operating System:
SoftPlan can be used with a 64-bit the Windows 11 operating system. The SoftPlan program is not compatible with the macOS® operating system. See "Will SoftPlan run on a Mac?" listed below for information on using SoftPlan on a Mac® computer. Configurations such as terminal or server operating systems as well as iOS, Android™, Linux® and Sun® Solaris™ operating systems as well as remote access are not supported. System RAM: At a minimum 4 GB. Preferred: 8 GB+ In general “more is better,” but there is a point when adding more no longer provides a significant performance boost. Where that point will be, however, is difficult to predict.
Graphics card:
See ‘What type of video card does SoftPlan require?' listed below.
Additional requirements: 2 button mouse/pointing device. 15GB of available hard drive space for program installation. 1 USB type A port. If only USB-C port(s) are available a USB-A female to USB-C male adapter can be used (not supplied by SoftPlan). An internet connection during installation and while using the program.
SoftPlan requires a video card that at a minimum is capable of supporting Microsoft® DirectX® 11 (DX11) but will offer significant performance improvements when used with a video card which supports DirectX 12 (DX12)¹.
Depending on the card, a higher number of pixel shaders, vertex shaders, stream processors, and ray accelerator cores will generally yield better performance. SoftPlan runs well with the majority of mainstream graphics cards recently released, but it is important to keep the video driver current. For more information on updating the video card driver check the card manufacturer’s web site.
Minimum Video Card:
At least DirectX 11 support, 1 GB+ dedicated RAM. This class of cards may support DX12 but do not support DX12 ray tracing. They are suitable for 2D and basic 3D work but use a much slower software based ray tracing engine native to SoftPlan and some SoftPlan 3D features will be unavailable.
Examples² include: graphics cards in this class have now generally reached EOL (manufacturer End Of Life)
Better Video Card:
DirectX 12 support, 6 GB+ dedicated RAM. This class of cards support DX12 ray tracing but have no dedicated ray tracing hardware. They are suitable for advanced 3D work, but will result in longer processing times than video cards in the Best class.
Examples² include: NVIDIA GeForce GTX 16xx Ti or AMD Radeon RX 5xxx
Best (Preferred) Video Card:
DirectX 12 Ultimate support, 6 GB+ dedicated RAM. Video cards in this class have dedicated hardware for Ray Tracing and Physically Based Rendering for the fastest processing.
Examples² include: NVIDIA GeForce RTX™ 3xxx (and newer) or AMD Radeon RX 6xxx (and newer)
Exclusions: Workstation class graphics cards such as the NVIDIA RTX PRO series, RTX Ada Generation, RTX A-series and legacy Quadro® series, as well as the AMD Radeon Pro (formerly FirePro™) series, are not recommended as they tend to deliver lower performance when used with SoftPlan. SoftPlan is designed to take advantage of features provided by so-called ‘gaming’ cards which most workstation cards lack.
Limitations: Integrated graphics (i.e. no separate graphics card) often do not have dedicated RAM, instead sharing memory with the system in general. This is common with both laptop and desktop computers and can result in inferior performance as compared to that of a separate graphics card.
¹ SoftPlan version 2020 and all earlier versions of SoftPlan do not make use of DirectX12.
² Examples are for reference only and program compatibility is not guaranteed.
SoftPlan will not run on any Mac which uses a M1, M2, M3 or M4 chip.
In the past SoftPlan could be run in several ways on Intel based Macintosh systems which used macOS. Boot Camp software allowed you to choose at start-up which operating system, macOS or Windows, to use.
Parallels Desktop and VMware Fusion software were used to create a virtual Windows environment within the Mac operating system.
Will SoftPlan and/or SoftPlan reView run on the Microsoft Surface family of devices?
SoftPlan and SoftPlan reView can be run on those Microsoft Surface devices which have an x64 processor (Intel® or AMD®) and use the Windows 11 operating system.
SoftPlan and SoftPlan reView are not compatible with the Windows RT operating system and cannot be used on devices that use it. Examples³ include the original Surface and Surface 2 tablets.
SoftPlan and SoftPlan reView are not compatible with the ARM processor and cannot be used on devices that use it. Examples³ include the Surface Pro X, Surface Pro 11 and Surface Laptop 7.
³ Examples are for reference only.
Does SoftPlan work with MiTek?
Yes - the SoftPlan model can be directly exported to MiTek SAPHIRE.
Does SoftPlan’s 3D include the ability to do a “Ray Trace” rendering?
Yes - selecting "Rendered" mode in SoftPlan 3D results in a "Ray Trace" rendering.
There are several home design software programs. What’s the difference?
You are probably looking at several programs ranging in price from $750.00 to $6000.00. Programs towards the lower end of this price range will likely easy to learn at first but due to their history as consumer products they tend to become limiting very quickly and will not provide the ability to complete highly detailed working drawings. Most of the programs towards the upper end of this price range are going to allow you to complete working drawings, but will lack ease of use. SoftPlan is and always has been targeted to the professional user and is the only program that combines an easy to use interface with the ability to complete highly detailed working drawings, 3D renderings and material take offs. SoftPlan does not charge annual maintenance or support fees.
What can you tell me about 3D in SoftPlan?
It's fast, easy to learn, and easy to use. A to-scale three dimensional rendering of your model appears at your request instantaneously during any phase of the drafting process. SoftPlan allows you to apply countless textures to three dimensional surfaces - e.g. hardwood, carpet or tile to floor surfaces; brick, siding or stucco to exterior wall surfaces; etc.. To bring your model to life, various lighting, which casts incredible shadows and reflections, can be added. Sunshine, representative of various daytime hours, is easily simulated. Even create exterior or interior spotlights, lamps, and overhead lighting - it's all available, and nothing short of amazing! 3D views are generated in different modes such as Wire Frame, Hidden Line, Shaded, and a Textured 3D. The Textured 3D shows different surfaces such as brick, stone, siding, shingles, etc.
Some home design software targeted at consumers say they include materials lists. What makes SoftList different?
SoftList is much more powerful than any other integrated material list module and the resulting list more complete. What other software developers sell as a "Materials List" is a simple listing of the items that you have drawn on the screen. SoftList has the ability to count materials via logic based material definitions. Items that are not drawn are counted based on the presence of items that are on the drawing. For example, if we were to draw a 8' x 10' stone patio a lesser design package may report that the 80 sq ft of material is required. What you draw is what gets counted. SoftList on the other hand, based on the presence of the same patio, can calculate the volume of the excavation; the rolls of landscaping fabric, the length of edging, the volume of gravel and stone dust, and the number of stones required, each with pricing and a waste factor. So, there is a huge difference between a simple schedule of materials and the comprehensive materials list that SoftList is capable of producing.
Does SoftPlan have a Trial Version?
Yes, when running the SoftPlan Demonstration select the "Let Me Try" button from the lower right corner. If your computer is connected to the internet, a drawing session will begin.
How Often Do Updates Come Out?
SoftPlan issues two types of updates. New versions and updates.
New Versions: A new SoftPlan new version is quite large and incorporates many new features. Historically new versions were released on average every 24 to 36 months. Newer versions will be released every 24 to 27 months.
Updates: From time to time, SoftPlan will release updates (patches) between the release of new versions. These updates often include minor adjustments and can be downloaded free of charge.
Does SoftPlan contain manufacturer catalogs?
Yes - click here for a list of building product suppliers that have content included in SoftPlan.
