3D
Door opening animation ability added to 3D walkthroughs.
Andersen
Andersen A series Specialty Oval windows added.
Annotated Elevations
Improvements made to placement of Opening Sizes and Opening Hinges on Annotated Elevations.
Block Move
Block Move can be used to relocate an arrangement of Openings along a Wall.
Center
Center Opening improved for Openings in Walls defined with zero width materials.
Change Size
Change Size command added to Opening Edit, allows the next Narrower, Wider, Shorter or Taller Opening from the same library to be selected.
Draw Select
In 3D Draw Select of an Opening replicates the Trim and Grill settings of the source opening on the new opening.
Openings can be Selected from one floor and drawn on another.
Garage Doors
Grill placement on Garage Door Elevations improved when the size of the glazing section varies widely.
Openings IDs
Arch openings of different sizes are assigned different Opening IDs.
Tall Doors
Tall equivalents added to the Door Libraries.
Door opening animation ability added to VR sessions.
Opening Schedule
Glazing Area for specialty windows that contain a deflection are properly calculated.
Virtual Reality
