Block Move
Opening ID, Product Code and Opening Size can be relocated via Block Move on Annotated Elevations and Sections.
Marker Lines
Add Marker To Other Side command added to Edit of an existing Marker Line.
Default Color Configuration option added to Elevation Marker Lines.
Marker Line labels on Elevations and Sections can be formatted as Multi-Line Text.
The Marker Line label text on Elevations and Sections is masked.
Improvements made to the placement of Marker Line label and Roof Pitch labels on complicated projects.
Openings
Improvements made to placement of Opening Sizes and Opening Hinges on Annotated Elevations.
Shutters
Repeat Edit of Shutters enabled on Elevations and Sections.
