SoftPlan 2024 New Features: Miscellaneous
Copy
Distance field is automatically highlighted when copying an item.
Draw Select
Draw Select command can Select on one Drawing and Draw on a different drawing.
Keyboard Shortcuts
Toggle Attach added to Keyboard Shortcut Configuration.
Toggle Group added to Keyboard Shortcut Configuration.
Toggle Link Floors added to Keyboard Shortcut Configuration.
Toggle Select Point added to Keyboard Shortcut Configuration.
Toggle Visible Only added to Keyboard Shortcut Configuration.
Toggle Shape Dimension added to Keyboard Shortcut Configuration.
Toggle Symbol Dimension added to Keyboard Shortcut Configuration.
Line Types
3 new dashed line types added.
Modes
Assign Drawing Modes on Menu option added to System Options.
Selected Modes will display a shortcut in the upper right corner of the screen.
Selections
Add/Remove Selection command added to the Tools menu.
Shape
Elliptical Arc command added Draw>Shape>Arc>Elliptical Arc.
Snap
Projection Snap points are generated from a Reference Point.
System Options
Folder Locations option dialog simplified.
Updates
Check for Updates command added to Help ribbon bar.
Visible Items
On Drawing vs. All options added to the Visible Items dialog.
Visible in All Modes option added to the common tab for Shapes, Symbols, Beam, Extensions and Dimensions.
Already was an option for Notes.
