Release 2024.2.2
Feature: Barn Doors
Description: Newly created Barn Doors were generating an overlap like they are sliding doors. This has been corrected.
Feature: SoftPlan Palette
Description: In certain circumstances a drawing’s palette could become all black after exporting a planset to dwg/dxf/pdf. This has been corrected.
Release 2024.2.1
Feature: Page Fault
Description: In a specific project moving a specific drawing in and out of the floor stack could cause a crash. This has been corrected.
Feature: Component Stairs | Rise | Number of Risers
Description: When editing a multi-component stair and change the stair rise from the Whole Stair tab, you cannot change the number of risers in the same edit. You must OK to close the stair edit after changing the stair rise before you can edit the number of risers. This has been corrected.
Feature: Copy To Clipboard Slow
Description: Copy to clipboard can take a long time when you have many tabs open. This has been corrected.
Feature: Copy to Clipboard | selection Set
Description: After creating a selection set, the “Copy to SoftPlan Clipboard” command does not work when selecting it from the ribbon menu. This has been corrected.
Feature: Opening hinge | open in model
Description: The Up hinge option no longer displays with Open in Model checked. This has been corrected.
Feature: Page Fault
Description: Switching a elevation or presentation between the DX12 and DX11 renderer can occasionally cause a page fault. This has been corrected.
Feature: Reverse | Mirror | Casement Swing
Description: When using the Reverse or Mirror command, Casement Swings aren’t updating. This has been corrected.
Release 2024.2.0
Feature: Color
Description: When changing the color palette via editing an entity and not though the project options dialog the color palette changes are not saved. This has been corrected
Feature: Wall Extraction
Description: In a particular project a wall fails to extract in 3D. This has been corrected.
Feature: Get Results From Server Dialog
Description: In certain conditions multiple “Requesting Server Information” dialogs appear on screen. This has been corrected.
Feature: Overlay | Color | Black Background
Description: When setting the background to Black and using default colors the overlay color remains black. This has been corrected. If ‘Use Item(s) Color’ is enabled and the entity’s color is the same as the background, the color will be swapped with white or black as appropriate.
Feature: Page Fault
Description: A page fault was resolved involving a particular project, Annotated Mode and Editing.
Feature: Page Fault Corrupt Project
Description: SoftPlan page faulted opening a specific corrupt project. This has been corrected.
Feature: Plan Set Page | Copy/Paste SoftPlan Clipboard | Drawing
Description: Copy/paste drawings between Plan Set pages using the SoftPlan Clipboard did not work. This has been corrected.
Feature: Project Palette
Description: The project palette was not initializing properly from the system palette. This has been corrected.
Feature: SoftList
Description: In certain circumstances a threading error could occur generating SoftList. This has been corrected.
Feature: Symbol dialog | Size
Description: The symbol dialog would not retain its size when using multiple monitors in a particular configuration. This has been corrected
Release: 2024.1.9
Feature: Child Window closes program | MISC
Description: In certain circumstances closing a child window could close the entire program. Steps were taken to reduce this possibility.
Feature: DWG | Overlay
Description: In certain circumstances exporting a DWG with an overlay could stack the drawings improperly. This has been corrected.
Feature: Edit Note
Description: A note edit dialog could appear offscreen on multiple screen systems when an additional monitor is not present. To the user the system appears locked. Edit Note dialog will now move onscreen automatically.
Feature: Elevation | Reverse | Roof Pitch | Opening Text | Operation Indicators
Description: When reversing a saved elevation, the Roof pitch indicators, and Opening information such as text and hinge/operation indicators do not reverse with the drawing. This has been corrected.
Feature: Elevations | Plan Set | Child Window
Description: When you have a Child Window that shows a Plan Set page with Model Views (Annotated is OFF), when the main window is active the live model views in the child window are not visible until the child window is made active again. This has been corrected.
Feature: Exterior Wall Not Extracting
Description: In certain circumstances with improperly formed joins exterior walls may fail to extract in 3D. This has been corrected.
Feature: Hinge | Opening
Description: In certain circumstances casement windows may fail to extract their hinge sides properly in elevation. This has been corrected.
Feature: Model Paint | Right Click | Elevation | Section | Interior Elevation
Description: When saving an Elevation/Section/Int Elevation as a line drawing and including Model Paint, you can no longer right click the Model Paint to obtain the context menu. This has been corrected.
Feature: Multi Drawing | Insert Drawing | File
Description: When going to ‘File>Insert’ and selecting a drawing that is a part of a Multi Drawing, it doesn’t let you click to place the drawing. This has been corrected.
Feature: Annotated Images | Tone Mapping
Description: In certain circumstances combining dx 12 with tone mapping would cause associated annotated images not to generate. This has been corrected.
Feature: Open Project | Annotated View | Keyboard Shortcuts | Initializing
Description: In certain circumstances when first opening a project, keyboard shortcuts don’t work in the active Annotated Elevation until you activate another tab, or change from annotated to model. This has been corrected.
Feature: Opening | Trim | Elevation
Description: On a saved elevation drawing, if you explode an opening symbol that contains brick trim it will explode into lines. Saved elevations now correctly add “Elevation Opening Symbol” and “Opening Exterior Trim” entities.
Feature: Overlay| Plan Set| Crop
Description: In certain circumstances a drawing with a cropped view and an overlay with does not appear properly on the Plan Set page. This has been corrected.
Feature: Right click Edit | Stair
Description: Using the right click context menu to edit stair display properties from the floor above could cause a page fault. This has been corrected.
Feature: PDF Export | Plan Set
Description: In certain circumstances exporting plan set to PDF the plan set stops drawing the plan set paper on screen. This has been corrected.
Feature: PDF Print | Autoscale Pen Width
Description: In certain circumstances when exporting a PDF, all linework is displayed when the PDF is opened in the viewer, but a physical print of that PDF will miss printing several wall lines and stair lines. This is because the minimum line width allowed by the PDF was less than the width the printer could process. The minimum line width has been increased to 0.05mm.
Feature: Reverse | Multi Drawing | Undo | Page Fault
Description: In a specific project doing an undo of a reverse all drawings in model could cause a page fault. This has been corrected.
Feature: Section | No Background | Wall | Wallcovering | Opening Trim
Description: When in a section view that has Background disabled, the entire length of walls being cut through will display if one or more openings in that wall have interior and/or exterior trim enabled, AND a Wallcovering is fully covering the wall(s). Sections without background now properly shows just the part of the wall being cut.
Feature: Share Project lock message | File
Description: The “previously opened by this key” lock message could occur on historic projects which were not in the cloud but had tickets created for them. Old projects in this state will now have the lock message appear one more time on open and then will correct themselves.
Feature: SKP Smooth edges | 3D
Description: Removing SKP edges flagged as smoothing edges was causing issues in some elevations. They are visible again.
Release: 2024.1.8
Feature: Deck Hole | Edit Edge
Description: The edit dialog for a deck hole edge has overlapping controls. This has been corrected.
Feature: DWG export | Plan Set | Text
Description: When a Plan Set is exported to DWG any text on the plan set is being given a black background. Backgrounds are no longer exported
Feature: Elevation | Save as Drawing | Marker lines
Description: When saving an elevation as a drawing, if the view has been opened using the camera rather than selecting it from the navigation bar, the marker lines are not saved consistently. This has been corrected
Feature: Export DWG | Plan Set |Overlay
Description: When exporting Plan Set pages to DWG in a specific project, it seems to stall on the Export dialog. The overlay drawing’s arcs were being converted to line segments for clipping resulting in 200K lines. We now convert to both lines and arcs resulting in a faster export.
Feature: Elevation | Section | Interior Elevation
Description: Right click on the elevation, section, interior elevation drawings in the navigation and select “Open View” will open a view with no annotated modes available. Re-saving drawings from this view will not save elevation marker lines. Annotated mode is now available when selecting “Open View”
Feature: Inset Frieze| Inset Banding| Profile
Description: In a particular project, on the Gable End above the Garage, if both the Gable End Frieze and the Banding below are both set to Inset, the Profile of the Wall in the Gable End will disappear. This has been corrected.
Feature: Page fault | Flip between annotated and model
Description: If you flip to annotated mode and then back to model mode before the annotated view is finished generating a page fault can occure. This has been corrected.
Feature: Print | overlay
Description: In a particular project using reference points an overlay drawing would not print properly. This has been corrected.
Feature: Project Invormation | State Abbreviation
Description: When using the abbreviation for some States in the Project Options (ie: CO instead of Colorado), pressing OK and returning to the Project Options, it changes to read the full name of the State. This has been correcteed.
Feature: Recover Error | File
Description: In large projects if you print the large planset to pdf and then close SoftPlan. then reopen SoftPlan and attempt to print the planset again, softplan will display message boxes saying a file needs to be recovered. This has been corrected.
Feature: Roof mode | Performance
Description: In projects with rafter or joist hangers enabled, SoftPlan could take a long time to open the drawing in Roof mode, or, switching the Drawing to Roof mode. This has been corrected.
Feature: Set Distance Between | Edit Dimension | Page Fault
Description: In certain circumstances a page fault can occure when using the set distance between or edit dimension commands. This has been corrected.
Feature: Site Lines | Linestyle | —X—
Description: A linestyle in the Siteline.def file was improperly defined resulting in the —x— linestyle that Fence defaults to being missing. This has been corrected.
Feature: Site Object | Insert Break
Description: If you insert a break into a site object and then try to adjust an edge near the point you did the break SoftPlan will Page Fault. This has been corrected.
Feature: Site Object | Insert Polygon Edges | Page fault
Description: Ability to Insert Polygon Edges in to a Site Object has been removed as it did not work and was never intended to work on those objects.
Feature: Soffit Rake overlap | Roof
Description: When you have a raked soffit and raked fascia the soffits on a hip to gable join overlap instead of mitering to each other. This has been corrected.
Release: 2024.1.7
Feature: Block Copy | Copy
Description: When selecting a the number of items you want to place you no longer get a preview of the new individual items. This has been corrected
Feature: Building options slow
Description: If have you a lot of building options or layers and you have the open set to hide the unused layers or B.O.’s, there is a long delay whenever we turn on or off or update the table. This has been improved.
Feature: Unselectable cross section entities
Description: Cross section entities from older projects (version 2020) may not be selectable for actions such as block move. This has been corrected.
Feature: Deadlock | 3D | Roof | False Gable
Description: Under certain conditions a false gable on a roof could case a deadlock. This has been corrected.
Feature: Elevation/Section | Building Option
Description: In 2022 we could set markers to a building option in a saved elevation drawing, this is no longer an option in 2024. This has been corrected.
Feature: File does not exist
Description: The “File does not exist” error dialog could display improper text. This has been corrected.
Feature: Openings | Curved Walls
Description: Openings extract incorrectly in curved walls that go through an arc of greater than 180 degrees. This has been corrected.
Feature: SoftList | wall_area_no_open variable
Description: The wall_area_no_open variable is not calculating the correct area when openings are in the wall. This has been corrected.
Release: 2024.1.6
Feature: Edit Opening Bifold
Description: If you edit an opening and change the type to Bifold, the section box is not generating properly. This has been corrected
Feature: Export to PDF | Plan Set | Print
Description: Sometimes when exporting a Plan Set to a PDF or printing some pages would not print or export correctly after the first print. This has been corrected.
Feature: Roof | Multiple Floor Roof | Add Shed Roof
Description: Add Shed roof fails when selecting beam/wall from a specific floor plan. This has been corrected.
Feature: Roof | Multiple Floor Roof | Intersect
Description: Intersect roof edges fail to properly auto pitch when walls are from a specific floor plan. This has been corrected.
Feature: SoftPlan+ Project
Description: The “previously opened by this key and not properly shut down” message could display on a project not added to the SoftPlan cloud after a ticket was submitted on it. This has been corrected.
Release: 2024.1.5
Feature: Closing SoftPlan SoftList Generator
Description: When you close a project softplan can appear to lock up because the softlist generator is doing a slow operation that we do not break out of. This has been corrected.
Feature: Cross Section Line | Edit
Description: In a specific project editing a cross section line would cause the edit dialog to immediately close. This has been corrected
Feature: Duplicate Roof | Page Fault
Description: Duplicating a roof edge and then selecting the geble end of the false gable could cause a page fault. This has been corrected.
Feature: Edit Symbol definition | Page Fault
Description: In certain circumstances Editing a symbol combined with searching and double clicking could cause a page fault. This has been corrected.
Feature: Electrical Legend | Opening Legend |
Description: When adding an Electrical Legend with larger Symbols, Editing the legend and changing it to a Edited Schedule, then, closing and re-opening the Project, the cell pad shrinks to the height of the text. This has been corrected.
Feature: e Floor Framing Schedule | ID | Drawings in Model
Description: Drawings in Model schedule option was removed from schedules to which they did not apply.
Feature: Gable Vents | Bull Nose Roof Edge
Description: In certain circumstances a gable vent could not be seen when added to a bull nose roof edge. This has been corrected.
Feature: Keynote Schedule | Schedule Source
Feature: Move Block | Openings | Dimensions
Description: When block moving multiple Openings and their dimensions, the dimensions and extensions are removed when the openings are placed down. This has been corrected.
Feature: Drawing Mode | Touch Screen
Description: User page faults changing drawing modes using a touchscreen. This has been corrected.
Feature: Quarter Round Left | Opening
Description: The Specialty Quarter Round – Left window was not generating properly. This has been corrected.
Feature: Redo Page fault
Description: SoftPlan will crash when doing a redo in annotated mode. This has been corrected.
Feature: Roof Framing| Parallel Chord Trusses
Description: In certain circumstances Parallel Chord trusses are not extending the bottom chord long enough. They are not sitting on the exterior bearing edge on the high end. This has been corrected.
Feature: Roof and Ceiling Mode | Beam | Visible in All Modes
Description: Draw a beam in Ceiling or Roof mode. Edit it and turn ‘Visible in All Modes’ off. Beam is only visible in Drawing Mode, cannot get beam to be visible in roof or ceiling mode only. This has been corrected.
Feature: Roof Holes | Soffit
Description: Roof Holes are not generating Soffit along the slope of the roof. This has been improved
Feature: Roof | Dutch Gable | Frieze
Description: In certain circumstances a Dutch Gable is generating Frieze under the Hip portion of the Dutch Gable. This has been corrected.
Feature: Roof | False Gable | Overhang
Description: In certain circumstances involving false gables, a gap can occur between the gable end and the soffit. This has been corrected.
Feature: Roof | Gable Frieze | Follow Hip Return/Bird Box
Description: Follow Hip Return/Bird Box no longer works on Gable End Frieze Boards. This has been corrected.
Feature: Shutdown Not Responding
Description: Effort was made to prevent SoftPlan from going into a non responding windows state when shutting down large projects.
Feature: SKP Hidden edges
Description: Some SKP files designate some edges as soft. In SoftPlan we now treat these edges as hidden. Silhouette is required to see edges on soft edged symbols.
Feature: SoftList |GA Energy Code | Ceiling Insulation Check
Description: GA Energy Code Simplified report could issue a warning of missing ceiling insulation even though it existed. The report has been updated and corrected.
Feature: Speed Notes | Attributes Updated
Description: Speed note attribute behaviour has been made more consistent with version 2022.
Feature: Table Page Fault
Description: A page fault can occur if you combine a column and delete the last column in a table. This has been corrected.
Feature: Unit Openings | Header | Edit
Description: You were not able to edit the header of a unit opening in Framing mode. This has been corrected.
Release: 2024.1.4
Feature: Annotated Views and Marker Lines
Description: Annotated Views Marker lines visibilities could get confused if manually edited to be on alternate building options. Blocked editing of building options for these program generated objects.
Feature: Beams | Floor System | Support Studs
Description: Beams added in Floor System Mode are adding support studs in Framing mode, even though the beam is below the wall framing. This has been corrected.
Feature: Center Between Edges | Overlay
Description: You cannot use Center Between Edges and select two edges from an overlay drawing. This has been corrected.
Feature: Color Palette
Description: If the system level color palette does not match the project or drawing level color palette we sometimes draw the drawing with the system color palette and sometimes with the drawing. This has been corrected.
Feature: Curve Walls | Opening Extraction
Description: Openings in curved walls were extracting correctly . This has been corrected.
Feature: Dimension Text Preview | Move | Mask All
Description: While an item is being moved that has a dimension referencing it, the original dimension text is displaying overtop of the new dimension text . This has been corrected.
Feature: Edit Roof Page Fault
Description: On a particular drawing, editing a roof could cause a page fault. This has been corrected.
Feature: Electrical | Auto Place Outlets
Description: Auto Place Outlets fails to place outlets correctly in 2024.1.3. This has been corrected.
Feature: Exterior Siding Wall not displaying | 3D
Description: In certain circumstances/projects some walls would not display. This has been improved.
Feature: Planset Borders | File
Description: If the planset page uses a border file that is not located in a subdirectory of the EXE location we will not upload and download the border file to the cloud. Border files located under the projects folder will now upload to the could.
Feature: Roof | Truss Set | Add Sub Fascia | Generate Drawing
Description: If a truss set has the new Add Sub Fascia enabled, the trusses will not appear on a Generated Drawing. This has been corrected.
Feature: SoftList Tab resizing page fault
Description: In rare circumstances resizing the Softlist tab could cause a page fault. This has been corrected.
Feature: Textured Elevation
Description: If you switch an Annotated Elevation to Textured it is a model instead. You have to switch back to the Model option, then click Annotated again to generate the annotated. This has been corrected.
Feature: View File | Plan Set
Description: In 2024, when placing a 3D view file on a Plan Set, the 3D view is placed on top of a Drawing. In 2022, the 3D view was placed below the drawing. This has been corrected.
Release: 2024.1.3
Feature: 3D Smoothing
Description: Smoothing on a 3D surface edit did not have the same affect that it did in 2022. This has been corrected.
Feature: Cabinet Face Handle Placement
Description: The Single Panel Shaker Door style Handel placement was incorrect. This has been corrected in the new install.
Feature: Deadlock
Description: Walls at that are almost parallel that join could cause a very long display time when moved. This has been addressed.
Feature: Elevation Display Lines Silhouette Round Columns
Description: The Display Silhouette option was processing the round lines of columns differently than in 2022. This is was related to smoothing and has been addressed.
Feature: Elevations | Save as Drawing | Elevation Openings
Description: In certain circumstances elevation openings could shift in a saved elevation drawing. This has been addressed.
Feature: Geo-Location Point | Merge / Insert | Site
Description: Merging or inserting a drawing into another drawing could cause the destination drawing to have multiple copies of the geolocation point. This has been addressed and only one geo-location point is allowed per drawing.
Feature: Hinge Operation
Description: In a particular project the hinge direction descriptive tags could cause a buffer overrun. This has been corrected.
Feature: Insert Page Fault
Description: Inserting a particular drawing into a new untitled drawing could cause a page fault. This has been corrected.
Feature: Joist Hangers
Description: Single Joists on a 2022 project could have joist hangers added when opened in 2024. This has been corrected.
Feature: Lag | Plan Set | Roof Framing Labels
Description: In a particular project making modifications through move and adjust could take a long time. It was related to updating the plan set pages and the roof framing labels. This has been improved however closing the planset pages while the modifications are made still significantly speeds up the process.
Feature: Notes | Electrical legend | Resize
Description: When adding an electrical legend to a drawing the cell heights are not adjusted for the larger symbols. This has been corrected.
Feature: Openings | Selections tab | Group Properties
Description: When multiple group properties were added on the selections tab the vertical scroll bar was not displayed. This has been corrected. In windows 11 you have to move your cursor to the scroll area before the up/down scroll arrows will display.
Feature: File Performance
Description: Large numbers of geo-location points in a project could cause performance lags. This has been corrected.
Feature: Roof Extraction Deadlock
Description: In a particular project roof extraction could cause a deadlock. This has been corrected.
Feature: Satellite Image Deadlock | site
Description: In a particular project using overlays involving the satellite image could cause a deadlock. This has been corrected.
Release: 2024.1.2
Feature: 3d path trace render state
Description: Applying repeat edit can auto start a path trace and put the render buttoon in an incorrect start / stop render state.
Feature: Annotated Cross Section
Description: Annotated Cross Sections could incorrectly detect generated items as user drawn.
Feature: Annotated View Page Fault
Description: In a specific project “Add Marker To Other Side” could cause a page fault.
Feature: Copy and Paste Planset clipboard
Description: If you copy a table from a planset into the clipboard. and then you try to paste that table back into the planset, SoftPlan will Page Fault.
Feature: Deadlock Draw Hip Truss Set
Description: There is a potential deadlock when drawing Hip Truss sets.
Feature: Grille Style Lines 3D
Description: Display of grille style lines improved and made more consistent between DX11 and DX12
Feature: Check for Updates
Description: Under certain circumstances, check for updates could enter an infinite loop.
Feature: Opening glazing gap
Description: In 2024, openings that have several glazing sections are showing gaps.
Feature: Page Fault
Description: In certain circumstances deleting a column from an opening schedule could cause a page fault.
Feature: Page Fault
Description: Quick3D Ray Trace using the DX12 engine could cause a page fault.
Feature: Page Fault
Description: In a specific project SoftPlan could page fault when undoing a modification to shelves.
Feature: Page Fault
Description: In a specific project SoftPlan could page fault when using roof snap.
Feature: Page Fault
Description: When using SoftPlan via Parallels on a Mac, SoftPlan could page fault when extracting ceiling insulation.
Feature: Plan Set Repeat Edit
Description: Repeat edit was not working reliably to remove underline from a label on a planset.
Feature: Plan Set Polygon Cropped View
Description: Polygon Cropped Views were not generating properly on a plan set page.
Feature: Post Stretch
Description: Setting a post to have a stretch location could cause the width to scale incorrectly.
Feature: Repeat Edit wall Page Fault
Description: Repeat editing a walls to be 2′ in a specific drawing could cause a page fault.
Feature: Tab Group page fault
Description: In a specific project placing a 3D textured tab into its own tab group can cause a page fault.
Feature: Table Edit Resize
Description: After adding a Table or Schedule to a drawing and editing it, you could no longer resize the edit dialog by clicking and dragging an edge or corner with your cursor
Feature: Wall Definition | Section | Snap
Description: The section view of the wall definition would not display the snap points when snap is enabled.
Release: 2024.1.1
Feature: 3D Mode Options
Description: If DX12 is not available DX11 options may include Path Tracing options which do not apply. This has been corrected.
Feature: 3D Symbol Location Folder
Description: Using a symbol location folder that is not a sub folder of the install could result in a page fault. This has been corrected.
Feature: Base Cabinet Fill
Description: Base and tall cabinets with no countertop could incorrectly create the top capping piece of the cabinet box. An extra line is visible in elevation.
Feature: Drawing Template Files
Description: Specifying a different location for the drawing templates could cause the templates in the new location to be overwritten with the templates currently in memory.
Feature: Elevation Marker Lines | Explode
Description: Exploding an elevation marker link put a box around the not. This has been corrected.
Feature: Interior Elevation | Cabinet | Hinge indicators
Description: If hinge indicators are turned off for cabinets in the project options they are not removed from the annotated view. We now add and remove the hinge lines depending on the flag.
Feature: Log Wall Projection | 3D
Description: Some log walls could display with an incorrect projection in 3D. This has been corrected.
Feature: Mode Bar | Plan Set
Description: Switching between a plan set page and the drawing tab can cause the mode bar to be disabled. This has been corrected.
Feature: Multi Format Note | Highlight
Description: Multi Format notes show an odd highlight when edited. Only the border of multi format notes is now highlighted.
Feature: Opening Animations
Description: DirectX 12 is the only renderer capable of rendering opening animations. Non DX12 renderers now warn the user if trying to render an animation containing opening animations that the openings will not animate.
Feature: Roof Fault
Description: A roof could fault SoftPlan if all the edges were set to intersect. This has been corrected.
Feature: False Gable Fault
Description: Repeat editing a false gable with fascia on could fault SoftPlan. This has been corrected.
Feature: Plan Set Border Fault
Description: Selecting a Plan Set border not in a subfolder of the install location could fault SoftPlan. This has been corrected.
Feature: Plan Set | Selection Set Visibility
Description: Selection items on a drawing could cause them to become invisible on a plan set page where the drawing had been added. They reappear when the selection set is cleared. This has been corrected so selecting items will not cause them to disappear on the plan set page.
Feature: Ridge Caps
Description: Ridge Caps were not displaying properly on a particular project. This has been corrected.
Feature: Sketchup SKP File
Description: Sketchup version 2023 files can now be imported and exported.
Feature: SoftList Location Fault
Description: If you use a SoftList folder location that is not a subfolder of the install location SoftPlan can page fault. This has been corrected.
Feature: SoftPlan Plus | Start Page
Description: The first time you use version 21 SoftPlan prompts if you agree to some conditions of using Plus. When you agree you will still not have use of Plus features in that first session including seeing projects on the start page. This has been corrected.
Feature: Truss Set | Roof Framing
Description: Parallel Cord trusses on a single slope could generate too many framing members. This has been corrected.
Feature: Building Options | Plan Sets
Description: Custom building option visibilities could be lost on plan set pages when opening a 2022 project in 2024. This has been corrected.
