Arc Dimension
Arc Dimensions remain attached to Deck Polygons after an Edit or Cleanup.
Auto Dimension
Auto Dimension no longer removes existing Extensions or Dimensions but rather automatically fills in any missing Extensions and Dimensions.
Distance
Lines from an Overlay File act a as a source for the Distance command.
Block Cut
Dimensions and Extensions remain after using Block Cut or Insert Break on dimensioned or extensioned items.
Room
Room Dimension Size options added, select from Area, Width x Depth, Depth x Width or Longest by Shortest.
Rounding
Rounding option added to Decimal Feet Dimensions allowing display to an accuracy of 1, .01, or .001 feet, useful for Site Plans.
Set Distance Between
Lines from an Overlay File act a as a source for the Set Distance Between command.
Preview added to the Set Distance Between command.
Stair
It is easier to Dimension to Stairs with Round Nosing in Cross Section.
Wall Thickness
The placement of a Wall Thickness Dimension is not effected by the Enlarge Dimension Numbers option.
Zoom
Zoom Extents acts as expected when Add Text is selected on a Dimension, but no text is entered.
