Andersen
Twin Unit Casements added to the Anderson 100 series.
Barn Doors
Tall Barn Door library added to Interior Doors.
Brick Mold
Smaller Brick Mold profiles (1 1/2" x 1 1/4") added to Exterior Trim.
BiFold Doors
The leaf size of the door panels is identical on a bifold door in plan view.
Cladding
Cladding option added Parametric Doors, this allows one side to be a different finish that the other side, previously this was only available on 3D symbol linked doors.
Covering
Top-hung blinds added to Opening Covering options, these are placed inside the window frame rather than extending past.
Dimension Options
inchesinches added to Dimension Format options.
Door Frame
Doorstop on door frames extract in 3D model.
Door Layout
A parametric Door Layout tool has been added to Draw > Detail. This allows for the creation of Doors that maintain arrangement, sizing, and proportions of components as the size of the opening changes.
Energy
SHGC field reduced to show only 2 decimal places.
U-Value reduced to show only 2 decimal places.
Elevations & Sections
Symbolize Opening option added to Cross Section and Elevation Generation options. When selected Openings save as Symbols on elevations and sections. When deselected saved opening lines are placed on Layer by type allowing Pens and Visibility to be controlled.
Exterior Doors
Modern Door library added to Exterior Door and Tall Exterior Door libraries.
Fixed Windows
Library of Fixed Windows added.
Frame
Repeat Edit applies changes made to Frame Thickness and Frame Width.
If Door Frame Thickness is edited the Rough Opening changes size and the Opening remain the same size.
Extension Jamb option added.
Garage Doors
Glazed (Glass) door options added to default libraries.
Hardware
Dead Bolt option added to Opening Hardware.
Flat Narrow Lever added.
Header
Header Material dropdown selection can be opened multiple times in a session.
Impact Glass
Impact Glass option added, locate on the Miscellaneous tab.
Inset Trim
Exterior Opening Trim adds correctly when Inset option is selected on an Opening in a brick wall.
Marvin
Marvin Essential Sliding Patio Door library added.
Mullions
Openings that mulled together use the Cladding option from the single openings to allow the separate configuration of interior and exterior finishes.
Opening Schedule
Header Width column option added to Opening Schedule.
Trim
Use Interior Trim option added, allows interior trim to be placed on both sides of an interior bearing wall.
Reveal option added to Opening Trim Options, specifies the distance between the inside of the opening frame and the inside of the opening trim.
Non-printable trim displays dashed lines representing both the inside and outside edges.
Opening IDs
Working on drawings with Opening IDs visible could be sluggish, performance is now improved.
Panel Doors
5 Panel doors added to libaraies.
Beveled style added.
Panel Doors separated into libraries for Beveled, Flat Panel and Raised Panel.
Rough Opening
If a value smaller than the Opening Width/Height is entered into the Rough Width/Height feild it is auotomatically reduced to equal the Opening Width/Height.
Excludes Garage Doors and Barn Doors.
Search
Symbol Tags added to Openings, used by the Search when placing windows and doors.
Sliding Window
Hinges are reversed when a sliding window is reversed.
Threshold
Flooring and Threshold do not overlap in 3D.
Units
Openings or Unit Openings can be stacked on top of other Openings or Unit Openings without joining provided they are spaced more that a 2"x10" apart.
