Annotated Elevations, Sections and Interior Elevations
Annotated Elevations, Sections and Interior Elevations generate larger models on older less advanced DX12 video hardware.
Building Options
Overlay visibility is maintained as Building Options enabled or disabled on a Plan Set.
Cursor
The small Cursor shortcut key (~) is enabled in Plan Sets.
Title Block
Folder Location option added to System Options > Folder Location to change where Plan Set Title Blocks are stored.
Group Prefix
Trailing spaces are prevented from Plan Set Group Prefix names.
Notes
Mask works properly on all justification types of Auto Scale Notes on Plan Sets.
PDF Export
Save of a PDF from a Plan Set remembers the location and the file name and uses both as defaults for subsequent PDF Exports.
Select Pages option added to Plan Set Print, allows individual pages to be selected from within the Plan Set.
PDF Export
Select Pages option added to Plan Set PDF Export, allows individual pages to be selected from within the Plan Set.
Export Metafiles as Images option added to PDF and Batch PDF Exports, by default Metafiles are exported as Metafiles, selecting this option will reduce the file size of the resulting PDF.
Page
Option added to automatically divide the page in two horizontally adding 2 Drawings to a Plan Set Page.
The drawings will be added centered within the selected division taking the title block into consideration if present.
Title Blocks
Folder Location option added to specify where Title Blocks are stored.
Visible Items
Custom Visibilities option added to Elevations, Sections and Interior Elevations in a Plan Set.
