SoftPlan 2026 New Features: Walls
Alignment of Profiles in 3D
Profiled wall materials on coplanar walls (stacked), align in the 3D model.
Change Wall
Change Wall command defaults the Alignment option to Outside of Current Wall's Outermost Bearing Material.
Combine Like Walls
When a wall is broken into two or more wall lengths, or when two walls of the same type are initially drawn end to end, there may be a need to combine the multiple wall lengths into a single wall again. New to SoftPlan 2026, the Combine Like Walls command makes this process simple and quick. Using this tool, SoftPlan automatically locates the end points of neighboring walls of the same type. By clicking these endpoints, the wall lengths are combined into a single framed wall that maintains any openings that were previously within the walls.
Footings
Visible Items has separate entries for Wall Footings vs Walls, allowing for a Footing only drawing to be created.
Joins of different width Footings improved.
Wall Materials
New Wall Materials added for siding:
  • Siding-Cedar
  • Siding-Cement
  • Siding-Metal
  • Siding-Vinyl
  • Siding-Wood
Drainage Mat material added for use in Wall Definitions.
Stairs
Clip Stair to Wall command added to the right click of a wall, removes the portion of a straight stair that overlaps the wall, modifying the shape of the stair.
Splash Board
If the Splash Board is thicker than the Corner Board it will extend and form the corner.
Stepped Footings
Sloped Footing Base option works with a single step in the wall height.
Tools
Combine Like Walls added to the Tools menu, takes two adjacent coplanar walls and joins them into one provided the height and offset are identical, openings, extensions and dimensions are maintained.
Trim/End Options
Independent option added to End Treatments, allows end options to more easily be edited concurrently.
Finish option added to Wall End Treatment, allows different finishes to be used on different walls or on different ends of the same wall.
