SoftPlan 2026 New Features: Roofs
Accent Trusses
Performance improved when working on a Roof that contains an Accent Truss.
Accent trusses with minimally deflected bottom chords are properly formed.
Brace (Post)
Roofs can directly reference the sides and ends of a Brace.
Building Option
A Roof Edge will retain its reference information when the visibility of the Wall, Beam, or Post it references is toggled on and off.
Cricket
Formation of Crickets improved when placed against larger gable end roofs.
Drip Edge
Drip Edge option added to Rainwater Management section of the Fascia/Soffit tab.
Fascia
Extend option added to Gable Corners, lengthens the Fascia to cover the Gutter.
Fascia formation improved when a Bird Box is set to have a custom width.
Fascia on Flat Roofs improved.
Frieze
Gable Frieze on angled walls improved.
Gable Corners
Formation of Gable Corners improved on angled roof sections.
Independent Gable Corners switch side when a drawing is reversed.
Gable End
3D Textures on a Gable End lineup with the textures on the wall below regardless of the direction that the wall was drawn.
Gable Freize
Inset Frieze option added to Freize Board on Gable Ends.
Gable Frieze properly forms when the roof is referenced to Beams, over a front porch for example.
Gable Vent
Inset Trim option enabled on Gable Vents.
Gable Vent width is editable when the Gable End is not being proved by the roof.
Gutter
Drop from Fascia option added, allows the Gutter to be lowered on the Fascia.
Lock
Roof Options: Pitch, Overhang, Heel Height, Seat Cut, Butt Cut and Top to Fascia can be locked so that they remain constant while other values are changed, for example if the Top to Fascia value if locked the Fascia will remain level even if the Pitch were changed.
Log Wall
Soffit, Fascia and Bird Box formation on Log Wall structures improved.
Match Roof Planes
Match Roof Planes command works on Roof Edges with different Top of Top Plate to Bottom of Fascia values.
Material
Torch Down roof material added.
Performance
The time it takes to place Fascia, Soffit and Freize Board on complicated roofs is reduced.
Preview
Fascia and Shadow Board added to Preview in Roof Options and Roof Edit.
Roof Edges
Unreferenced Roof Edges, added via Add Roof Edge or as a Hole, have the same edit properties as a Roof Edge that is referenced to a wall or a beam.
Roof Material
Roof Material Profile option added, models individual Clay Tiles or Standing Seam, roof material components in 3D.
Roof Plane Style
Intersect Outside added to Roof Plane Style, automatically aligns the outside of a vertical intersect roof place with the outside of the wall material.
Saddle
Saddle formation improved when the two roof planes forming the valley are pitched differently.
Soffit
Cover Sub Fascia option added to Soffit, extends the Soffit to the meet the Fascia below the Sub Fascia.
Corrected issue where Soffits that are overlap or are in close proximity to lower soffits could invert.
Default Soffit Material option added to Finishing Options.
Soffit Material added to Roof Options defaults.
Transition Boards
Transition Boards can be successfully added to Multiple Floors Roofs.
Transition Boards form better on Roof Edges that also have Gable Frieze Boards or higher Heel Heights.
