SoftPlan 2022 New Features: Move
Center in Room
Right Click lists Center in Room command when applicable. An example is a right click of a ceiling light in electrical mode.
Center in Room | Center Between Edges
Text contained within a Symbol is ignored when centering via the Center in Room or Center Between Edges commands.
Plan Sets
Block Move added to Plan Sets.
Stairs
Stairs will "bump" into Walls on a Move making placement easier.
Notes
Block Move selection of Notes reduced.
Make Parallel
Items in a Selection Set can all be rotated by the Make Parallel command.
Room Label
Room Labels are easier to locate.
Walls
Moving wall we allow selection of the inner and outer most visible lines, previously the trace line was always selected.
