SoftPlan 2022 New Features: Wall Framing 3D3D Framing Visible Line view can be saved as a SoftPlan Drawing. Lines (edges) between coplanar framing members display. 3D Framing ViewWall Strapping is extracted in 3D Framing Views. Jack StudExtend Jack Above Header option added. OpeningIf an opening does not have a header framing is added over the opening. HeaderAdd Plate Above Header option added. Used to create boxed headers. Steel I Header Type added. PanelWall Panel drawings generate a print shaded making it easier to read. SillExtend Sill through Jack option added, the jack studs will be cut into 2 pieces. Steel StudsSteel Studs extract as "C" sections in Framing Mode and 3D Framing. StudAdd Stud on Flat command added. Places a new Stud parallel to the wall.
