Why do I have two keys for my Educational installation?
One key is labeled 'Master Key' and the other is labeled ‘Registration Key.’ Both keys which make up a pair will have a matching key number also on the label. The Master Key will need to be installed on a system anywhere within the network. It is suggested that the key be on a system such as a teacher station or in a server room. If the Master key is not installed, none of the workstations will be able to open SoftPlan. The Registration Key is used to add individual WorkStations to the registration list of the Master Key. The number of licenses is controlled by this list and any WorkStation on the network that is operational needs to be registered.
Where do I install the Master Key Manager?
Install the Master Key Manager Software where you intend to install the Master Key. This installation is required before any WorkStations can be registered. We recommend that the Master Key be installed on a computer with a fixed IP address for best performance. It must be on the same subnet as the computers accessing it.
Where do I install the SoftPlan WorkStation software?
Install the SoftPlan WorkStation software on each of the stations that are required to operate SoftPlan including the system with the Master Key installed if it is also required to run SoftPlan.
How do I install the Master Key Manager software?
To Install the SoftPlan Master Key Manager:
1. Insert the SoftPlan CD into the CD-ROM drive of your computer.
2. Select Master Key Manager Setup from the Installation menu.
3. The installation/update program begins. Follow the on-screen instructions.
4. Restart the computer after the SoftPlan Master Key Manager has been successfully installed.
5. Place the SoftPlan Master Key in the USB port.
How do I install the SoftPlan WorkStation software?
The SoftPlan Master Key Manager must be installed before installing the SoftPlan WorkStation. See: 'How do I install the Master Key Manager software' for instructions.
To successfully install SoftPlan WorkStation, follow the steps listed below:
2. Select SoftPlan Setup from the Installation menu.
4. Restart the computer.
I have the software installed on the WorkStation. How do I register it?
To Register the WorkStations:
Upon completion of the installation process, do the following on each WorkStation installation. Ensure that the Master Key is still installed on the network where the Master key manager was installed.
1. Insert the SoftPlan Registration Key in the USB Port of the WorkStation.
2. Start SoftPlan.
3. If the Computer has not yet been registered, a message will appear indicating that the WorkStation needs to be registered. Select OK.
4. The Program Authorization dialog will appear. Select 'Key Registration.'
5. The Computer Registration dialog will appear showing the current computer name at the top. Select: ‘Register this Computer’ and it will be added to the list of registered computers. Select OK from each open dialog and exit.
6. Remove the registration key, move to the next WorkStation and repeat the registration process.
When I start my HomeWork Station it requests a key number and registration code. Where do I find that information?
When the order was placed on-line an e-mail was sent to the e-mail address entered on the order form. The e-mail will confirm your order and contains the HomeWork Station key number and Registration Code required at start-up.
