My computer does not have a DVD Drive. How can I install SoftPlan on a computer that does not have a DVD Drive?
If you are a SoftPlan+ subscriber or a new user the installation is available for download here.
You can connect to another computer that has a DVD drive across a network, or copy the disk contents to an external drive such as a flash drive and install it from there.
I am having trouble starting SoftPlan after the Auto-Update process.
The Auto-Update may not have completed successfully, please follow the steps below.
- Reboot the system
- Download and run the latest patch for your version of SoftPlan from the Support > Patches page of the SoftPlan Website.
- Reboot the system after the patch finishes
- Start SoftPlan
I lost my installation DVD. How do I get another one?
Replacement DVD's can be ordered here. There is no charge for the installation disk but a shipping charge will apply.
Can I bring only my system settings from an earlier version of SoftPlan into my current SoftPlan install?
SoftPlan will allow you to restore selected parts of a backup created in another copy of SoftPlan (the same version or earlier). Select File > System Options > Archive. Place a check beside Configuration and press Restore. Exit SoftPlan and then open SoftPlan again to load the new settings. This will restore your System Option settings without replacing any other current version information.
I’ve purchased a new computer. Prior to installing the new SoftPlan Version, do I need to install the older versions of SoftPlan I own?
No, each version of SoftPlan is individual and does not require that previous versions be installed to operate.
How do I update my old Version to my new upgrade?
These versions are to be installed separately, not as an update. When prompted during installation from the CD to choose the type of setup, choose Typical Installation. This will install the new SoftPlan under its own directory.
How do the Automatic Updates work?
Update patches are automatically applied when SoftPlan is run on a computer which is connected to the Internet and the File > System Options... > Setup Options > Automatically Check for Updates option is enabled (checked). If the SoftPlan version is current, SoftPlan will only check for updates once a day when it is first started. If the SoftPlan version is not current, SoftPlan will check for and apply an update patch each time it is started until the version is current. Thereafter it will only check once each day. A Checking for Updates dialog will be shown during the program start up process, prompting you to download and install the update patch. If a connection to the Internet cannot be established or if the update server is busy, SoftPlan will attempt to connect each time it is started until a connection is established. Thereafter it will behave as outlined above.
Can I install my new SoftPlan Version on my computer and still use the old SoftPlan Version?
Yes, the new SoftPlan Version is a separate program from the old version. Both can work on the same computer independently of one another.
What operating systems (OS) will SoftPlan run on?
Version(s): 10
SoftPlan Version 10 will run in Windows 95, 98, ME, Windows NT. It will run under Windows 2000 or XP as long as the program has been updated to 10.2.1.
Version(s): 11, 12
SoftPlan 11 and 12 will run in Windows 95, Windows 98, Windows ME, Windows NT, Windows 2000, Windows XP Service pack 2.
Version(s): 13, 14
SoftPlan 13.3.4 or earlier will run in Windows 95, Windows 98, Windows ME, Windows NT, Windows 2000, Windows XP, Windows Vista.
SoftPlan 13.4.0 and 14 will run in Windows ME, Windows NT, Windows 2000, Windows XP, Windows Vista, Windows 7, Windows 8, Windows 10.
SoftPlan 2012 will run in Windows XP, Windows Vista, Windows 7, Windows 8, Windows 10.
SoftPlan 2014 will run in Windows XP, Windows Vista, Windows 7, Windows 8, Windows 10.
SoftPlan 2016 will run in Windows Vista, Windows 7, Windows 8, Windows 10.
SoftPlan 2018 will run in Windows 7, Windows 8, Windows 10.
SoftPlan version 2020 will run in Windows 7, Windows 8, Windows 10.
SoftPlan 2022 will run in Windows 8, Windows 10 and Windows 11.
When I try to open SoftPlan Version 14 I get a message that “The application failed to start because the application configuration file is incorrect.” How do I fix this?
You will need to install the MSVC++ Runtime update from the SoftPlan Version 14 Disk 1. Insert the disk and from the Launch menu select Utilities > Install MSVC++ Runtime. Once installed, you will need to restart the computer.
How do I install DirectX if I did not install it during the SoftPlan installation?
Insert the program disk, when the splash screen appears click on the Utilities button, then click on Install DirectX button.
After applying the 14.4.3 update patch, SoftPlan fails to open and displays a message similar to one of the following: “This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem.”
1. The update download can be found at the following link: http://www.microsoft.com/en-us/download/details.aspx?id=3387
2. The specific file to download and run is: "vcredist_x86.exe (2.6 MB)" from the ‘Files in This Download’ section.
3. Follow the on-screen instructions to download and install the update.
4. Reboot the computer and attempt to start SoftPlan.
I reinstalled SoftPlan and now when I attempt to open my drawings I receive the message “This drawing was created with a newer version of SoftPlan. It can not be read by this version.”
This indicates that your previous SoftPlan installation was updated to a newer release after it was installed from the program disk.
To update your SoftPlan program, click on the Check for Updates button on the System Options... Setup Options dialog. It may be necessary to repeat this process several times in order to update SoftPlan to a release able to open your drawings.
Alternatively, download update patches from the Technical Support area of the SoftPlan website, following the installation instructions provided on the download page. Again, it may be necessary to download and install more than one patch in order to update SoftPlan to a release able to open your drawings.
Users who have recently applied the 14.4.3 update patch and terminated the installation prior to the installation of the Microsoft Visual C++ Redistributable Update which is part of the SoftPlan update patch. Users affected will need to reinstall the Microsoft Visual C++ 2005 Service Pack 1 Redistributable Package ATL Security Update .
